na 13 and 14 sec cars i got a question - FirebirdV6.com/CamaroV6.com Message Board
  • na 13 and 14 sec cars i got a question
    what kind of gas milage do you have and what kind of problems with your car have you had because of the performance equip you use in your cars
    91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
    Hi... 13 sec NA here..
    My Mileage sucks pretty bad cause I drive the car hard and run with short gears.. used to be 3.73's will be 4.10's soon.
    I'd say I get 14mpg maybe on average. 7mpg when I go to the track.
    Driveability isn't that bad.. I drive with no front sway bar on nittos and skinnies,... you just have to be careful. Slow down for turns and you'll be ok. Space yoruself from the person infront of you, no tailgating.
    As for breakage.. Any time you tear into the engine you risk more problems. I currently have problems with mine.. probably a bad lifter.
    When you drive the car hard and don't change the tranny fluid often, you risk transmission damage.
    Thats about the only part failure I've had so far due to performance modification.
