E-Brake, Low Traction lights on - FirebirdV6.com/CamaroV6.com Message Board
  • E-Brake, Low Traction lights on
    Hello, i am new to this site.. it is sweet... but i am stumped on this one...
    I drive a 3.4L 94 Blk Camaro with t-tops... it is manual and has no mods. I have a system but that should not effect this.
    When i am driving my E-Brake light comes on and my Low Traction Light come on randomly at the same time... my e-brake it disengaged and i have brand new tires on my car... When i apply the e-brake without the warning lights on the e-brake light comes on by itself. Can anyone give me some input?
    i have ran a scan tool and nothing has come up... cleared all codes... it still happens... nothing is really wrong just it is very annoying to see them come on for 5 seconds or w.e then shut off.
    Re: E-Brake, Low Traction lights on
    I had similiar problems when one of the ebrake cables was sticking. Replaced it and problem went away.
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      but wouldent that just shut off the e-brake light? wouldent the "low Traction" still come on?
        do you have ABS? sounds like maybe an AB/TCS problem
        2000 3.8 A4 Pewter Camaro
          i have abs... but my abs doesnt work anyway
            well when you have an ABS problem, it can turn your brake and traction control light on. its its own warning system.
              i just put new pads and discs on my car, and i got new tires.. and new outer tie rods... i put it all on myself.. it was all very easy but the lights have come on more now that i did all of it... i had my instructor check everything i did and he said its all good... so why is it doing this now? and if it is my abs doing it... whats the best way to diagnose the problum?
