just out of curiousity about how long does it take to remove an engine from a 4th Gen? how high does the body have to be lifted in order to get the motor from underneath it?
engine removal
Re: engine removal
why are you removing the eng?
If you take it out from underneath(which is the easiest) you have to drop the k-member, keep the engine on the front wheels, and disconnect a few other things. This is considered unsafe because it might be hard to make sure the body is gonna stay up in the air.
I've never done it that way.
I've only pulled the eng from up top. I considered it easy cause I did it myself. The hardest thing is ya gotta pull the engine and tranny forward so you can get the bellhousing bolts off (which require alot of torque!).
I've got pics of it coming out from underneath though, if ya want them.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: engine removal
Originally posted by notsonicis it possible to fit a 350/lt1/ls1 etc from the top? or only the 6s1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: engine removal
probably, but again, its dangerous2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
