okay so heres the deal i was driving my car (95 3.4 maro) and i looked down and i notice im runnin WAY over 260 degrees im completly maxed out and from what i know about cars it could be a head gasket, water pump, crack head, and therm but im not for sure i need help bad though :(
Whoa temp way to high
Re: Whoa temp way to high
start by checking the thermostat. check the oil for coolant mixed in. if ya got coolant in there chances are you blew a gasket or worse.
Follow me!
Or this
oh yeah. and DO NOT DRIVE IT ANYMORE UNTIL YOU FIND THE PROBLEM AND FIX IT.!!!! it will make things worse.
Follow me!
Or this
can you tell if you have a cracked head by your idle because when i first got the car it was running about 800rpm now its running around 1200rpm this car is a mystery anti freeze keeps disapeering with out a trace and i have a cracked EGR tube
dissappearing as in leaking? if its dissappearing like that and not leaking id put money on it being a head gasket then.
Follow me!
Or this
go check the oil dip stick. you'll be able to see it if its in the oil. also if the exhaust smells sweet, thats another sign of it.
Follow me!
Or this
or white smoke2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by MAROA4L32i started it idel was at 1200 exhaust smelt normal and oil looks normal i think i am just going to sale the car i found a 92 Formula Firebird :)<a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
I have to agree with Oi Bird. dont sell it cuz a small problem. If your oil isnt cloudy then it isnt going there and thats a very good sign. Do the exhaust checks and the only thing i can add is go to auto zone and buy or maybe even rent (tool rental program= free :) ) a coolant system pressure gauge and connect it to your radiator and pressurize the system and see if the pressure drops at all which it should since you said it goes low alot or leaks. By checking it this way you can find if its a small leak at a fitting on the block and just vaporizes too quickly to notice when the car is normally started.
P.S i could send you pictures of the crazy looking wiring harness i am rewiring and maybe that will make you feel better about your problem
