I have done starters on 3.4s and 3.8s. It isn't hard at all. There are two big bolts holding it on (I think they are 15mm), and there are 2 wires connected to the solenoid.
Nothing has to be moved to get it out, except the heat shield, which is easy to remove.
1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
I just had to pull the 3.4 starter off to get the 4L60E in. You don't have to mess w/the heat sheild on the 3.4, 3 wires total, 1 big from batt, one more from wire harness to it, and then the small wire on separate stud.
[ December 14, 2003: Message edited by: 3.4 slow to go ]</p>
2013 Ram 1500 Big Horn
94 comero 3.4
