Okay, so my '98 3.8's air conditioner works perfectly fine. However, when it's not turned on, it makes a squealing/metal-on-metal grinding sound. The sound goes away when I turn the A/C on. Any ideas?
A/C Squealing..
Re: A/C Squealing..
look at your compressor when this happens and tell up what happens
Re: A/C Squealing..
Originally posted by NOS2006Okay, so my '98 3.8's air conditioner works perfectly fine. However, when it's not turned on, it makes a squealing/metal-on-metal grinding sound. The sound goes away when I turn the A/C on. Any ideas?
try spraying some WD40 on the pully
Re: A/C Squealing..
Yes, clutch can be replace independent of the compressor.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Re: A/C Squealing..
No you do not need to remove refrigerant to replace the pulley assembly. I think it makes it easier to have a good air compressor and a impact wrench to remove the pulley so that it doesn't turn while you are trying to remove it. Best thing would be to spend $10-15 on a repair manual and get the exact procedure. I did mine on my 3.4L Camaro, but it has been a while. Total time I had involved was about an hour or so.<br />RIP<br />1995 Chevrolet Camaro<br />3.4L V6 A4<br />Flowmaster 40 Series<br />K&N FIPK<br />Throttle Body Coolant Bypass<br />180 Degree Thermostat<br />3.42 Ring Gear<br />Steel One Piece Driveshaft<br />IAT Relocation<br />and a website <a href=\"http://www.geocities.com/jason_b298\" target=\"_blank\">http://www.geocities.com/jason_b298</a><br />New Ride 2000 S-10<br />4.3L V6 VIN W<br />auto <br />3.42 w/ LSD<br />more coming soon
