BCM interchangeability, this ones for you blldogg - FirebirdV6.com/CamaroV6.com Message Board
  • BCM interchangeability, this ones for you blldogg
    is a bcm from a 96 interchangeable with one from a 98, and does the fb/camaro make a difference?
    Re: BCM interchangeability, this ones for you blldogg
    dont think so. the biggest difference i bet would be the communication style. call a local dealer part department, ask them to look up the modules and compair part numbers and such. are you trying to get a used one? you know that even if it is the same, that you will have to have it programmed at a dealership and you car will probably not run until then.
    2000 3.8 A4 Pewter Camaro
      what has to be programmed, vats or something, i figured it was just the remotes that have to be programmed into them, interesting...
        O' ther is soooo much more.
