Sea Foam and PCV Valve - FirebirdV6.com/CamaroV6.com Message Board
  • Sea Foam and PCV Valve
    I just purchased a can of Sea Foam, but I need a little info. on how to pour this sucker through the PCV valve on my 3.4L Camaro. I unplugged the hose and turned the car on, but the damn thing started to idle extremely high and just kept going. Is this normal? Did I do something wrong or unplugged the wrong hose? On the 94 Camaro, I unplugged the hose that is inside the manifold that has the 3.4L logo on. It looks kinda like a "V shape and has two hoses connecting on it's sides. Was this it? I read that it is locate on the drivers side valve over. Please help me out. I searched the forum, but couldn't find anything.
    Re: Sea Foam and PCV Valve
    thats normal get a funal and pour it in you need some one to keep on the gas it weel want to die
      the hose youre talking about is a vaccume hose i think. the pcv valve should be on the lower intake IIRC.
      Follow me!
      Or this
        ill leave this open as long as it doesnt turn into ANOTHER seafoam thread. check the sticky up top for a complete guide on how to do it.
        Follow me!
        Or this
          Thanks for the help, will try again.
            what you need to unplug is a vacuum hose. it sounds like you got one, but the reason its idling so high is because you're introducing alot more air into the engine than was accounted for by the MAF, so the engine is getting more air, then it ups the fuel... ya see whats going on? but yeah, just yank off that hose, you should feel a good vacuum coming off it, and dont bother pouring (unless you're going right in teh pcv) the vacuum from the hose should suck it right outta the bottle for you.
              ya i used the hose coming off the brake round cynlider thing, put a skinny funnel into it and slowly pured some in then it died, waited a min, started it up pured a lil more in then it died again. let it sit for about 5 mins then started it up and it was runnin rough. not too much smoke came out while i was drivin it around the neighborhood gettin it flushed out. pooured almost a half pint into oil drove down to galveston and back then changed oil. also had some in the gas tank the whole time and i now notice a smoother operation and maybe a few ponies :banana: . i liked the fact its so cheap and effective that tomm ill be doing it to my moms 87 crown vic with almost 200,000 miles. she'll appreciate it im sure. i highly recommend this.
                av6xp, on your other thread that got closed, I could've answered your questions.
                  lol ya it did but i guess it was a repeated question. how does it raise the rpm vacumm and compression and is it the compression inside the cylnder it's talking about?
                    i have a 99 camaro and was wondering...is it absolutley necessary to change the plugs to do it...i dont want to do it if i dont have to i just changed them not too long ago
                      no you doent have to change the plugs the reason they sugest changing the plugs is to help slow the build up of carbon the hotter the spark the better the combustion the less carbon
                        oh alright i actually did the seafoam right after i posted it and it owrked amazing i watched the kids sown the street run around and play in all the smoke!! that stuff works!
