hey ppl i got a 97 3.8 with a little over 108k on the car i jus started it n there a ticking noise , the ticking noise goes faster with the rpms i checked the oil level n it ok wat can be the problem ???????? let me know thanx
Ticking Noise Coming From Engine!!!
Re: Ticking Noise Coming From Engine!!!
could be a multiple of things. exhaust leak, sticky lifter, fuel injectors, etc.
Does it go away when the car is warmed up?
i just started it right as im typing to see if it goes away when it warms up ..... but when i started it it was really loud for a couple of seconds then the ticking noise lowered down a little
sounds like it could be a sticky lifter then. Have you ever tried seafoaming a car? That might be able to burn up that carbon in your engine and keep the lifter from ticking.
Originally posted by CAMARODJDwhere can i get seafoam at n where do i put it in the vaccum line ?
the problem does sound like a lifter, could be bent, ect..
If its just a quiet ticking then I wouldnt worry. Lifters probably getting tired. My motor made all kinds of ticking and clanking then when I changed my oil instead of all castrol gtx oil I put a quart of lucas in and all noise stopped and oil pressure is higher =). Perhaps try that. Also dont get a fram oil filter, they are junk. Consider WIX.
Originally posted by TechAlso dont get a fram oil filter, they are junk. Consider WIX.
Same problem I have a noisy lifter, and its really annoying.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
