Like title said please help me.
No response from speed and rpm gauges
Re: No response from speed and rpm gauges
No clue, but check your fuses in the dash and under the hood. I don't know which one to look for, but alot of them are labeled on the fuse panel covers.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
yeah i tried to wiggle it, even unscrewed the cluster made sure the plug was in. If it means any thing It was working before I put in the new steering column, thinkk I could've done something wrong or broke something??
cehck the wiring to the vss. I recently had to repair those wires. Not sure if the tach was effected, as the needle had fallen off a while ago :o1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Originally posted by 3.4 slow to gocehck the wiring to the vss. I recently had to repair those wires. Not sure if the tach was effected, as the needle had fallen off a while ago :o
