Well i did a search on manual fan switches today , and found a "how to do" thing by one of the people from this site , thanks for it , helped a ton and wasnt to hard to do at all , well my question is just a simple one , on high speed is it normal for only one fan to go?On low both come on.
Fan switch
Re: Fan switch
Originally posted by StrtRacer98my write up.
high is one fan
low is one fan
It's normal.. if you listen, when the fan is on high it should be alot louder than the low speed.
Glad the how-to helped.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: Fan switch
mine was 2 wires, and a ground wire. Tapped into like H and J on the harness
Re: Fan switch
Originally posted by logan13883It was only 2 wires right? my low speed is both fans , but high is just the one ....Mines a 96 , would that make any difference?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
