where is one that will work on a 96 3.8 camaro? is it a good idea to get one?
where can i get an adjustable fuel pressure geuage for 96 v6?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
Caspers Electronics AFPR - This Adjustable Fuel Pressure Regulator takes the place of the factory unit. It is designed for and marketed toward the L67 supercharged GTP engine but it works with any 3800 Series II, naturally aspirated or otherwise. It is available from the Grand Prix Store for $155.
http://www.clubgpstore.com/itemview.asp?itemid=331999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
