The Case of the Missing Anti-Freeze - FirebirdV6.com/CamaroV6.com Message Board
  • The Case of the Missing Anti-Freeze
    I have a 2001 Camaro, 3.8L V6 that is losing anti-freeze about every 150-200 miles (add about 1 QT). I cannot detect a leak, no spots, drips or smell that I notice.
    Since noticing the problem, I flushed the system and refilled with new DEx-COOL. I also replaced the radiator cap. Still seems to be leaking.
    Any ideas on how to locate leak? Am I ready for Stop-Leak or a radiator shop?
    Re: The Case of the Missing Anti-Freeze
    no white exhaust smoke?
    did you have dex-cool in it before?
      Ive had this problem recently too.
      I cant put much in at one given time, so I havnt been TOO worried about it.
      I cant see any visible leaks, and dont have white smoke after warmup. My oil level hasnt gone up at all, and it isnt milky.
        if you have white smoke at start up that goes away after a little while, probably a small coolant leak into your cylinders that finally burns off and you cant notice after that point since it wouldn't cause a lot of smoke.
        2000 3.8 A4 Pewter Camaro
          Not trying to be Dr. Doom here....but.
          Only 4 ways to lose coolant:
          1) from engine/component to ground (hoses, water pump, radiator, heater core, etc...)
          2) from reservoir cap to ground (from air being pumped into cooling system from combustion chamber)
          3) internal leak into the oil system (intake gaskets, head gasket, cracked block/head)
          4) internal leak into the combustion chamber (and out of the exhaust) (intake gasket, head gasket, cracked block/head)
          So far every car that I've encountered with the syptoms that you described needed the head gaskets replaced.
          The lastest one was the father-in-laws Caddy STS. For years it would consume a quart of antifreeze every 1000 k miles or so. with no apparent traces of internal or external leaks or white exhaust. Then this spring the engine temps started to fluctuate. Changed the gaskets this summer and that fixed the problem.
            isnt DEX-Cool anti-freeze not good for your car? is it that orange colored A-F?
              yes it is the orange coolant and no it is not bad for your car.
              If you don't believe me, Call a GM Engineer who has at least a bachelors degree in automotive engineering and probably makes well over 100K a year.
                *calls GM* he said your full of it. Just kidding.
                I only asked because my friend had a 98 Blazer that used that anti-freeze, his car was overheating and the mechanics told him that that anti-freeze was causing problems. We even did a search on that A-F and it brought up a website with a boatload of people saying the same thing.
                Here's a site with people having problems with that A-F.
                http://www.consumeraffairs.com/autom...m_dexcool.html
                  i know, i have seen that sight
                    well, it's only a problem if you beleive that it'll last 150k miles or 5 years. if you replace it every year you shouldn't have a problem.
                    99 WS6
                    13.25@104.97 - Lid + soon to be more other stock items ;D
                    Originally posted by camaroextra
                    tears are great lube, but its hard to get a girl to cry onto her own ***.
                      Intake manifold gasket
                      Raven
                        do you have an auto or stick? if auto, check your tranny fluid for the evil stuff, and coolant for some foam floating bby the rad cap.
                        2013 Ram 1500 Big Horn
                        94 comero 3.4
                          X2
                          dex-cool=:bs:
                          Originally posted by kala
                          TEAM BLACK!!!
                          parting her out
                            My dex cool still looks brand new after 4 years/40K miles. I will still change it though, either next year or the year after, when I reach 50K. At that time I'll replace the hoses too. After reading about all the issues, I just check it a couple times a year to make sure it still looks good.
                            I think that as long as you (1) don't mix green and red, and (2) maintain your cooling system properly, it works fine.
                              hmm. every few weeks ill start my car up and a puff of white smoke comes from the tail pipe. but only right when it cranks. it this a problem?
