hey everyone i have a problem my car is starting to over heat n i dont know whats the problem . ive already changed the water pump , thermostat , all the hoses so if anyone has had this problem b4 please direct me in the right direction o its a 97 3.8 t-5 n its has abot 109,XXX miles on it
over heating
Re: over heating
make sure you bleed the cooling system, there is a little valve on the pipe where the thermostat is. You just open that up a little bit until coolant flows out.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: over heating
I 'd let it warm up a little so a little pressure builds, then just turn it a little bit to let the air out. When you see coolant coming out you're all set. Just don't do it when it's totally hot.... because you'd be overheating anyway, probably. And you'd have high pressure in there.
And yeah stop leak sucks, never use that stuff.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: over heating
yea I had an air bubble in my lines when I replaced my thermo, it was overheating so I had to bleed the air out with that little screw
Re: over heating
i let the engine warm up to at least the same temp of the thermo
open the bleeder
shut off car
let it let out all the air
close
fill radiator
repeat2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: over heating
Originally posted by Rob Bellmake sure you bleed the cooling system, there is a little valve on the pipe where the thermostat is. You just open that up a little bit until coolant flows out.
I cant find this bleeder could it be anywhere else or what does it look like cause im haveing an overheating problem too?
