please anyone help i put anti-freeze in my car and didnt know i needed some drained because i wasnt thinking and now my car is overheating almost all of the extra anti-freeze has already flowed over and leaked out but it still overheats do you have any idea's on what my problem is?
Over Heating??
Re: Over Heating??
bleed the cooling system ANYTIME you open the cooling system
its a closed system, if air gets in thur it will make you overheat
bleeder on the 3.8 is on the drivers side of the TB
the 3.4 is on the passenger side of the TB2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Over Heating??
you are always going to heat up more while idling because air isn't moving through the engine bay. First try bleeding the air out of the system and see if there is any. Are you losing coolant or did you just loose the extra and now it is sitting level?
