tips on removing stuck bulbs? - FirebirdV6.com/CamaroV6.com Message Board
  • tips on removing stuck bulbs?
    So i know its a dumb question, but my tail light bulbs are a b***h to take out. I had to replace one and i had to pry it out, i did that at the expense of gouging the housing pretty bad. New bulb went in fine but i'd rather not go through another half hour trying to take off one bulb while messing up the housing in the process. Have they just melted on pretty bad? what can i do to remove the rest of the bulbs more easily? since i want to replace all of them now that one side is brighter.. any tips are appreciated and my apologies again for asking about such a simple problem
    Re: tips on removing stuck bulbs?
    No help in getting them off (I had to order new fog light housings and sockets they were melted so badly), but unlike GM remember to use some bulb grease when you put in the new lights. It'll help next time you need to change, and might even act a bit like a heat sink compound to spread the heat out a bit and prevent future problems.
    2001 Pewter Firebird Y87, M5
    Go Sabres!
      get a pair of these:
      Use them religiously. You should have no problem getting the bulbs out of the housings.
      \'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
        Ive had to use a pair of wire cutters to crush them then pull them out by the filament. Only bad part is glass gets everywhere.
        01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
        www.vaperz.com
          mine twisted right out??
            thats exactly what i did with the first one. man i was hoping there was a magical lube that would get it right out:naughty: :naughty: but damn i guess i'll try my best to pry the rest out.
            lol skorpian, i thought for a second that those were some contraptions that take out bulbs--realized they're those things that work out your hands--lol
            yeah i wish mine came right out
              I'm sure you could use the to take the bulbs out. It's not going to be really effective, but you could use them.
                use needle nose pliers crack the bulb and them muscle it out. it always worked for me.
                1997 Camaro LS1 RS
                1994 Camaro - Sold
                1999 Trans am Vert - Sold
                A Few Mods....
