why is there oil comming out of a gromet on the passanger side of my 3.4...the pcv valve is on the driver side...this it just an empty ruber thing??
Wtf Is That!!!! Oil!!!!!!!!
Re: Wtf Is That!!!! Oil!!!!!!!!
Check your PCV valve to make sure it's not clogged. Air is supposed to go out through there. The tube on passenger side from the intake is supposed to draw clean air into the engine, not spit oil out. You will get some oily residue in the throttle body but it should not be dripping. If you want to eliminate that put a small filter on the passenger valve cover and get rid of the tube.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
don't spray the maf sensor and also a new PCV valve is like 5 bucks and should be replaced on full tune ups anyways
