I had that in my clutch line , new slave and just have master replaced with new McLeod - what a difference , totally different driving experience. Fluid stays clean. Probably seals where leaking or something. Wounder if rebuild kit does exist for brake MC?
yeah. its normal for it to turn a dark color. if it has no transparency at all, maybe but it is normal for brake fluid to be dark.
ASE GM Tech....LOL . It is not ok to have dark brake fluid. If it is dark its from rust in the system and/or from heat from heavy break use. Dirty break fluid will fuk your ABS up. Flush it again.
