Looks like I have (maybe) a Eurolamps kit, w/the whole headlight assy swapped, not just a 9005/6 conversion. The h4351 lamp burnt out. Does anyone know if eurolamps sell just replacement bulbs? Just wondering before I shoot them an e-mail asking the same.
Or does anyone else know of just a vendor selling the bulb itself???
thanks
2013 Ram 1500 Big Horn
94 comero 3.4
Also.. this is for those that need a FULL list of EVERY bulb on the camaro. (this should fit all first rev, 4th gen camaros)
1994 CHEVROLET Camaro
Low beam headlamp
H4351
High beam headlamp
H4352
Parking light
2397
Front turn signal
2397
Rear turn signal
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
2057
Stop light
2057
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
885
License plate
194
Back up light
1141
1141LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Ash tray
194
Glove box
194
Map light
212-2
Dome light
906
Step/Courtesy light
562
74
Trunk/Cargo area
562
Under hood light
93
Instrument-general
161
194
37
Check engine indicator
161
Hi-beam indicator
161
Seat belt indicator
161
Brake warning
161
Automatic transmission indicator
73
Directional signal indicator
161
FirebirdV6.com/CamaroV6.com Administrator
Stupid is rewarded with the ban button.
Official Avatar Nazi according to Meatyshells :D
You can heat up the housing of the stock bulbs which will allow you to remove the stock bulb from the housing. It will soften the glue and you can get it out. Then, clean out the rest of the sealant from the surrounding glass. Out stock lights use the same connector as a 9006 bulb. From there, you can put a 9006 bulb back in the housing using RTV sealant to hold it in. Make sure that it is fully seated and sealed to prevent moisture from leaking in. Put the whole assembly in a vice while wrapped in foam or towels and allow RTV to seal. This will allow you to choose what bulbs you want in there from now on (PIAA, Silverstars, etc.) and replacements are MUCH cheaper.
the drivers side was easy, didn't have to heat anything up, just cleaned it out, trimmed teh edges of te 9006 bulb & applied the rtv. about 2hrs later, applied some more as insurance. The pass side was a diff brand, and I jsut went ahead & applied liberal use of a dremel tool & cut it, cleaned it up, countersunk the connector top & then hit it w/rtv twice also. I'll worry about the highbeams after I get a new high beam switch installed.
94 comero 3.4
