instrument bulb replacement?dangerous? - FirebirdV6.com/CamaroV6.com Message Board
  • instrument bulb replacement?dangerous?
    Hey guys I need your help,
    I brought my car in for service today and well after giving a list of a few things I needed fixed, I was told that replacing the bulb that was burnt out behind my fuel gauge in the instrument panel was not covered under my warrentee and that it would cost about 100 dollers to fix. So I asked if Its easy to fix myself and the service employee said I HAVE to use static proof gloves and that I could easily set the air bag off trying to fix this. Is this the case? And if not does anyone know the easiest way to replacing a bulb back there? Its really ennoying so sooner I get it fixed sooner my attitude towards my dealer drops.
    Thanks,
    Matt
    New ride: 98 firebird-y87-appearance package-t=tops-MINT-Tri-flo-K&N-SLP CAI [img]graemlins/burnout.gif[/img]
    Old ride: 94 camaro- t-tops-tri-flo-K&N-underbody neons-Unbelievable condition- SOLD
    for the 99 i have its ****in easy i replaced all 8 of mine for the hell of it cause i was bored took me about 30 minits and most of the time was wasted looking for a socket that would get to the damn bolt heads ( bad place ment ) it isnt worth the 100$ not even close, i plan on doing my own guage fases pretty soon =D indiglows here i come!!
    no dude you just gotta pull it apart and stuff the 99+'s are hella easy and as for the 98s im not sure so if there the same as a 99 your set other than that i dunno
    91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
      Lord-gufi or anyone, do you guys know what bolts I must unscrew and what I should do to make this as quick and easy as possible.
      Thanx
      Matt
        Just make sure to disable the airbag system but removing the fuses and such for it just in case. AS far as being hard I haven't personally done it but from other people's work I've heard it is fairly easy just be gently and nice and easy with taking it off, you don't want to break anything on your dash or the panels itself. Get a service manual, like a Haynes or such and it should tell you the bolt type and size and everything you need to know. Do a search on the board, someone has posted about this many times before.
        [ October 09, 2002: Message edited by: Skullcamaro ]</p>
        1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
          Well guys I did a search and couldn't find much at all. I thought i have read a "how to" thread on this before but I guess not. If any of you guys have done this before could you give me a brief description on how to take care of this.
          Thanx
          Matt
            Its very easy. Definitely not worth $100 in labor.
            And please do me a favor and kick the guy who told you that he had to wear "static gloves".... what a moron [img]graemlins/thumbsdown.gif[/img]
            Basically, you start by undoing the plastic part underneath the sterring wheel. After that comnes off, you'll see the other screws to take off the speedo cluster itself. After you pull out the whole speedo cluster, the bulbs are in the back of it, just twist and pull them out. If you want to change the color of the backlight (mine's red) now is a good time to do it.
            You can do this yourself man. All you need is a 8mm (?) ratchet and some patience. [img]smile.gif[/img]
            Hope this helps... :D
            E-mail: ibjanky@yahoo.com<br />AOL IM: IBJanky
