Just wondering... - FirebirdV6.com/CamaroV6.com Message Board
Just wondering...
  • Just wondering...
    Well i seafomed my 98 today, and the SES light is on. Is this just from the Seafoam being in the motor? NOt much smoke came out either....
    Re: Just wondering...
    did you add it to the gas tank? make sure the cap is on correctly.
    2000 firebird w68, auto, t-tops , 3.42 , k&n, whisper lid, taylor 8mm spark plug wires , bosch spark plugs , 3\"in/out carsound CAT , 3\" i pipe, take off trans am muffler, C6 Z06 rims
      Can you tell any noticeable difference with the cars performance for your SES light to be on? Go to your local Autozone and have them scan it so we can see what the code is.
        i put it in the tank Monday when i filled up, then put it in the oil right before putting it in thru the brake line...
          have you checked the plugs.
          Follow me!
          Or this
            Check your plugs to see if they have fouled out (any of them) and also, go ahead and change your oil. Once you have changed your oil, drive around for another 50 or so miles and change it again.
            Also, make sure that your brake line is on securely.
              How about you have the code scanned
              2000 3.8 A4 Pewter Camaro
                You said not much smoke came out after seafoaming it. After you let it idle for a little bit, did you take it out for spin? At that point not much smoke came out?
                If it didn't, first thing I would like to know is how many miles are on your car? Maybe you just don't have muce carbon build up in your engine.
                Secondly, maybe there is a problem with your exhaust, are you running stock cat, and how old is it? It could possibly be clogged up and not letting your exhaust come out as it needs too.
                  SOme came out when i took it for a spin, but not as much as i had expected. It has 111,xxx on it. I have an after market muffler, but im pretty sure the stock cat.
                  well i took it to the chevy place neary and they said it was.... crap... what ws it..... the thing that measures the air coming in the motor... oxygen sesnor.. maybe... F)*K! i cant remember. anyway they said it be like 280 to replace it!!!!! I just gave them 169 a month ago to replace a coil!
                    MAF sensor. they are expensive and very much needed
                      maf sensors / coil installs can be done by anyone with a wrench.
                      a coil alone costs $20-$48 at oreilly's
                      so they charged you about $133 just in labor, which it
                      would only take me like 10 minutes to change!
