ive heard all of these could be making my engine do this. what do u guys think?i have a 94 camaro 3.4 v-6 -when i mash into the gas she stutters and shakes and sounds as if shes misfiring-but as long as im light on the pedal shes fine and will run perfect.think its the tps?? what are the symtoms of a TPS going bad?:rant:
tps? egr? maf?
Re: tps? egr? maf?
yeah, what they both said ^^^
first bought my car, she did that spitting and sputtering. changed the plugs and wires and she came to life. here recently she started doing it again, but just a little differently. turned out it was my coil packs, so yeah... well hopefully you figure it out.
Re: tps? egr? maf?
Originally posted by alexhoughtonive heard all of these could be making my engine do this. what do u guys think?i have a 94 camaro 3.4 v-6 -when i mash into the gas she stutters and shakes and sounds as if shes misfiring-but as long as im light on the pedal shes fine and will run perfect.think its the tps?? what are the symtoms of a TPS going bad?:rant:
I do not think that the TPS would cause those symptoms.
I do not think that the EGR valve would cause those symptoms.
