need input - FirebirdV6.com/CamaroV6.com Message Board
need input
  • need input
    i will give the camaro gas to go up in mph and it will be fine, but soon as i maintain my speed she will start to buck. i would think that it would be a misfire but it's not happening when i'm givin it gas. my air/fuel gauge is reading a little high. she doesn't try to stall out. and the rpms are fine. oil and everything looks good. when i had my second little blow up with the nitrous the only thing that didn't get replaced is my maf screen. i think that i just need to replace that.
    INPUT?
    WAWA-A-HOLIC
    Re: need input
    maf sensor is the first thing that comes to mind for me. Have the car running and try tapping the maf sensor and see if it starts to run different.
    http://www.bowtiev6.com/
      Re: need input
      Or even uplug the MAF sensor and drive the car to see if that clears it up. If it does help then youll need to retune the MAF sensor. Ive had a similar problem after my cam install and it was the MAF sensor. It wont hurt the car at all to drive with it upluged, but the car will bog down a bit when you are slowing down which is normal. Hope tha helps a bit Kristen.
      01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
      www.vaperz.com
        Re: need input
        I had that same problem with another one of my cars, but it would also do it when I was trying to get up to speed and while cruising.The problem was the U-joints I replaced those end of problem.
          Re: need input
          i know that mine has something to do with the maf. so i ordered the screen and i will go from there. it's pouring in philly today anyways so i can't do anything about it.
          WAWA-A-HOLIC
            Re: need input
            Not sure if it's the same or not, but I have a MAF from my 1996 Camaro.
            Give me a ring and stop by if you want. I'll be replacing the stock brake pads (that leave brake dust like crazy!) on the GTO today with Ceramic Pads.
              Re: need input
              96 maf is different than the 99+ mafs
                Re: need input
                Trying unhooking the MAF sensor though and drive for a bit with it unpluged and see what happens. If it gets any better then there is your answer.
                www.vaperz.com
                  Re: need input
                  Not sure if you determined if it is a misfire or engine problem, but sounds like it could be the transmission lock up kicking in and out. Is this the kind of "bucking" you are experiancing?
                  Try driving with the Overdrive off (D not OD) and see if this changes anything.
                  Just a thought.
                    Re: need input
                    before you damn the maf, take some electronics cleaner (somethign that leaves NO residue) and spray off the little wires in the maf.... i know that maf's do goofy things to a car and when you had your little mishap, maybe some gas residue got stuck on the wire causing it to get mis-calibrated.
                    I would also take a good look at your vacuum lines. If you're accelerating and taking in more air and making a rich a/f mix, a vacuum leak wont kill it that much, but if the engine is trying to optimize the a/f mix and you're leaking in more air, then things could get hairy... besides, who knows what got ripped apart when you had a small hiroshima goin on under your hood..
                      Re: need input
                      If you have a scan tool check to see how many grams per second it's flowing . I know gm has a chart somewhere for it . I think at idle it's like 6 or 8 but i cant remember . That will tell you if the maf is working right .
