belt tensioner - FirebirdV6.com/CamaroV6.com Message Board
belt tensioner
  • belt tensioner
    My wife has a 98 olds 88 with the 3800 Series II. The belt tensioner's bearings froze and burnt up the belt. I was looking at the tensioner and was wandering if it's any different than that which is in the camaro and the firebird? How big of a pain is it. My 3.4 was two bolts but that doesn't seem to be the case here.
    Re: belt tensioner
    its not that bad, the worst part is that the heater core hoses come through it somehow, but its doable, i am not sure if its the same on that car
      Re: belt tensioner
      had the same thing happen on my moms 98 monte carlo, also a 3800 series 2. you can get just the pulley with a new bearing in it. only thing to remember is the bolt holding the pulley on is a left hand thread.
      foggy headlights? wetsand... buff... WAX!!!
      if nissan motorsports is nismo does that mean honda motorsports is homo?
        Re: belt tensioner
        X2
        STEEL Tensioner pulley (p/n 24506756) $18.15
        Raven
          Re: belt tensioner
          thanks for the part number firebirdgt. Been needing to get mine replaced, its getting loud.
          Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
            Re: belt tensioner
            yeah, i guess my whole shebang was worn when i got mine done, otherwise yeah, just replace the pulley
              Re: belt tensioner
              How does it get worn out? I understand the pulley. My pulley was 115k, buddies camaro was 105k, and gf bonneville was 90k. But how does a steel assembly that has fluid pass through it get warn out? I'm curious.
              Originally posted by kala
              TEAM BLACK!!!
              parting her out
                Re: belt tensioner
                the tensioner is a little bit more than a steel assembly with a pulley. theres a spring type mechanism in there that keeps tension on the belt, hence the name "tensioner". that spring dosent last forever.
                  Re: belt tensioner
                  This is probably true but i dont see it all of a sudden getting worn out. It could happen though.
                  TEAM BLACK!!!
                  parting her out
