How to program a key fob for our cars? Also, how to reset the pcm after installing a high flow cat and cai? If anyone knows about either one of these, please let me know. Thank you.
Wasn't there a Tech board for???
1997 Camaro RS Convertible<br />White w/black top, factory chrome rims <p>Mods so far: Borla catback, Catco high flow cat,CAI,2 point STB,painted calipers and drums with caliper camaro decals,GTS blackout all the around,5% tinted windows all the way around,Streetglow red neon lights inside and under, raised camaro fill in decals on the rear, 30th anv decals, and a nice stereo system<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=275528\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=275528</a>Tags: None
for the key fob that is in your owners manual.. if you don't have it let me know and I'll scan the procedures in from mine for ya.. I imagine the 97 procedures and 98 are likely the same.. as far as the PCM I have heard conflicting reports of how to do it so I'll leave that to someone that knows..-Brad
2000 V-Star Custom 1100
:rock:
I'm pretty sure that it tells you how to program key fobs on www.installuniversity.com Last time I looked it was there.- JT3<br />1998 Red V6 Camaro Y87 Y3F - J.E.T. Chip Stage II - Clear Parking Lights - Removed Grill - K&N - Whisper Lid - !FRA MOD - MAF Screen Removed - Pro 5.0 - Pacesetter Headers - Magnaflow Catback - 32mm Front Swaybar - And A System(bump bump)
<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
<blockquote>quote:</font><hr>Originally posted by AMinor65:
Resetting the PCM:
http://ls1.com/link_ecm.html<hr></blockquote>
BAD idea!
If you plan on disconnecting your battery, think about how your PC would like to be unplugged while it's running. There is no difference.
There is NO reason to disconnect the PCM, unless you are trying to clear a SES light that won't go away - even then it's not a great way to do it.
http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=007803
[ October 09, 2002: Message edited by: FirebirdGT ]</p>Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
after putting my cai on, I now have the ses light. So I heard I have to reset the pcm because of this. It has a high flow cat as well. As far as the key fob, thanks guys. I bought a manual off ebay a while ago, but misplaced it. Guess I have to find it.1997 Camaro RS Convertible<br />White w/black top, factory chrome rims <p>Mods so far: Borla catback, Catco high flow cat,CAI,2 point STB,painted calipers and drums with caliper camaro decals,GTS blackout all the around,5% tinted windows all the way around,Streetglow red neon lights inside and under, raised camaro fill in decals on the rear, 30th anv decals, and a nice stereo system<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=275528\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=275528</a>
First you should make sure the:
1) IAT sensor is plugged in and working. You can do this using Autotap or at a dealership.
2) The O2 sensors are plugged in and functioning properly.
Both types of sensors are durable, but easily screwed up.
As for the PCM...when the car is turned off, what function exactly does the PCM perform?
Unplugging the battery won't hurt a thing.
Unplugging a PC hurts because the hard drive is VERY sensitive to electromagnetic fluctuations; ie, power brown/blackouts and surges. The magnetic platter can be physically/magnetically damaged by yanking the plug while RUNNING. When off, pulling the plug only has a derogatory effect if unplugging/replugging the AC causes a power surge unrelated to the actual activity of unplugging it.
Unplugging the PCM can only be harmful if the PCM takes a nice zap from the battery. Otherwise unplugging it is NOT detrimental unless it's done while the car is RUNNING as the data tables, etc get screwed up and corrupted like a BIOS can if you yank the plug on a PC repeatedly during a boot.......
R
<blockquote>quote:</font><hr>Originally posted by Rich97 W68:
Otherwise unplugging it is NOT detrimental <hr></blockquote>
I do NOT agree, but we could argue this forever. Do what you wish, it's your car.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
