I know this may be a relatively easy thing to do, but I can't do it. How do I replacement my headlight because my left light blew out. I have a 2000 3.8L camaro?
Headlight Replacement?
Re: Headlight Replacement?
There are two plugs on the backside of the headlight, one for low beam and one for high beams, they have tabs on them that you have to push down and than turn the plug. Doing this will allow the bulb harness to come out, replace bulb and harness and you're done.
Originally posted by tbonebuggsDoes anyone know what the replacement number is at Autozone or Advance Auto Parts?
Not to flame you, but this is something you should be able to figure out of on your own. I mean, if you can't change a bulb, how are you going to change a flat or change your oil?
