Coil packs - FirebirdV6.com/CamaroV6.com Message Board
Coil packs
  • Coil packs
    How do I trouble shoot coil packs? I think mine might have a problem. I have tried new wires but I cant get my car to kick over...(details to it all in advaced tech)...
    [ December 31, 2002: Message edited by: edge24_99 ]</p>
    \"If I have seen further, it is by standing upon the <br />shoulders of giants.\" (Isaac Newton)
    You take them off and check their resistance. The correct values are listed in the Haynes manual. Try searching if you haven't already. We've covered this a few times.
    And change the topic name to "coil packs" not "oil packs" :D
    [ December 31, 2002: Message edited by: Dojo2000 ]</p>
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      you could also get a spark tester tool and see if the coils make a spark...
      Silver \'98 Camaro M5<br />Current MODs:<br />SLP strut tower brace; SLP 1LE swaybars front/back; Powerslot rotors; Hawk pads; Eibach springs; Bilstein SLP shock kit; SLP trans mount; Zexel limited-slip differential; LS1 drive shaft.<br />Possible future MODs:<br />BMR Lower Control Arms; BMR Pandhard Rod.
        is there an online Haynes manual?
        <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
          take the wire off the plug from the coil you want to test. stick a screw driver in the end where it touches the metal end of the wire, the hold the metal part of the screw driver over the bracket behind the a/c. have someone crank the car and look for a strong blue spark. anything yellow and the coils are starting to go. it's not perfect, but it will give you a good idea if you don't have access to a voltometer.
          and the easiest way to pull the back coils off is to pull the whole module first, so you can tilt it.
          you can\'t get off if you don\'t get on
            You can also have the zone test them for free.
              <blockquote>quote:</font><hr>Originally posted by RUC:
              You can also have the zone test them for free.<hr></blockquote>
              They are inaccurate. I got mine tested at that place and they told me that its still good but yet when I put it back on it misfires coz of it.
              <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
