okay so I think my battery is dead RIP. just clicking when I go to start... but it could be my altenator since the battery is getting no charge whatsoever.. or maybe the battery is completely dead and just won't take a charge? Not sure how old it is but looks old, I might get a battery from work, I get a discount.
Dead batt
Re: Dead batt
I believe they'll also test your alternator for free too if you want to get it checked out. Most likely it's your battery just being old though since you said you think it's fairly old.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Dead batt
i just had the same problem. first, check the bolts on the side bolt, unscrew and screw them back in. for my car, it started up again, but kept having same problem so i just replaced my battery today and no problems so far.
Re: Dead batt
this may not be the case with urs but ill give a lil input....i noticed you had a headlight conversion...was it just the higher bulbs, or did u convert to a round headlight style setup luike the ryo-tek kit? Cause when i converted my lites i had under-drive pullies too and the power level kept killing my alternator...took those lights out, replaced them with stock and it never had a charge issue againm/
Re: Dead batt
Thanks for the info... ended up replacing the battery and everything is fine... It is just converted from the sealed with the higher output bulb... that could be a reason but I have had those in for a year or so now
