PLZ HELP! high idle and whine from motor *update*** - FirebirdV6.com/CamaroV6.com Message Board
  • PLZ HELP! high idle and whine from motor *update***
    well i start the car and it revvs up to like 3500-4000 rpms dunno why but it followed by a whine which seems to be coming from the starter anyone ever have this problem? Im pretty lost w/ this one as to what it can be, i took the starter off and it seem to look fine, i messed w/ the wiring and put it back in but it continued to whine WTF can it be
    any help would be greatly appreciated
    thanks in advance.
    [ June 02, 2004, 04:12 PM: Message edited by: pontiac nino ]
    ---Niño---<br /><i>95\' silver 5 spd</i>
    Sounds like it might be a pulley or something.
      did you just put the motor in or mess with the computer
      [ May 12, 2004, 11:02 PM: Message edited by: new2thegame ]
      1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
        When i first got my car it would rev to aboutr 2500 when starting it and whine. I replaced the belt and it stopped.
        Don't know about your high idle tho...
        96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
          you have the 3.4 right? There is a vaccum fitting right above/next to where it says 3.4 SFI on the intake manifold.
          Check in that area and you will see some sort of T connection, this connection is for a vaccum and when this connection some how came loose in my car, the car would idle up at around 3.5-5k.
            alternator whine mabey? also try shooting some WD40 into the hubs on your pullies if the whine stops I would say you have a bad bearing on that pully...
            Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
              this ain't no whine from pullies i've heard that before, the first couple of times i turned the motor on when i barely dropped it, it had a idle of about 8-900 rpms now for some reason i turn it on and it immediately goes up to like 3500-4000 rpms and the whine is coming from the passenger side underneath the car, i thought the line to the throttle was stuck but it's not
              the car did this b4 it even have suction from the vacuum, i know this cause the was no suction at first till i found out that the intake was not bolted down right :eek:
              i've disconnected and reconnected the computer thinking it would reset it but no dice.
              all vacuum fittings are on right thats what i thought it was too at first a loose fitting
              vampyr, i think it maybe the alternator but i hear the sound coming loud from underneath the car
              i'll check again though
              hell i even took off the transmission thinking it was the flywheel nope :(
                bump [img]graemlins/burnout.gif[/img]
                  well i figured out what the high idle was throttle positon sensor had the throttle half open, i took off the tps then mounted it back on right, still can't find the whine though oh well
                    Wait for car to be dead cool...
                    pull the belt off and start it up for a few seconds and see if it whines still(remeber be weary your car will overheat pretty quickly)
                    this shocul narrow down if its a pulley or belt problem [img]smile.gif[/img]
                      Already did that, still the same side effects, oh yeah funny sh!t too i put the transmission back on today and it won't go in gear, think slave is fecked up maybe clutch in backwards.
                      WHY DAMMIT WHY!
                      [ June 02, 2004, 03:56 PM: Message edited by: pontiac nino ]
                        funny thing is it was the alternator crapping out on me, i messed w/ the lower and upper intake a bit and it brought the idle down to 2k rpms then i left the key on the ignition turned as if i was gonna turned the car on, well i hear a funny *** hum wasn't the fuel pump cuz it kept going, hum kept coming from the alt. took it to go get checked and thats when i found out the bearing on it were crapping out and it wasn't making enough amps. new ones on but i still have a idle of about 1500 rpms dunno what the hell that is but i guess i'll give it some time to see if it goes away, thanks guys
