I have a 98 3800 camaro with almost 91k. My car almost over heated on me today and I had to pull over before it did. I let it cooldown and checked the coolant level which was really low and noticed that there is a leak that looks like it is coming out of the front of the block. I noticed it on the belt and then ran it and saw it was almost pouring out from under the block. I checked the radiator hoses where they connect to the engine and they were sealed well. Any ideas where the leak could be coming from and how to fix it, hopefully without spending too much.
Coolant leaking from engine block
Re: Coolant leaking from engine block
The small plastic elbow behind the tensioner pully assembly.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
waterpump giving out would be my guess
If it is the water pump or gaskets would it still cool the engine? If I fill the radiator the car will cool the engine at the right temp until the coolant leaks out. Thanks for all the suggestions.
Gonz
no, if the water pump is toast there wont be coolant flowing thru the motor.
Follow me!
Or this
It's the plastic coolant elbow attached to the waterpump.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Originally posted by FirebirdGTThe small plastic elbow behind the tensioner pully assembly.Originally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
exactly wats wrong with mine..they have the kit at oreillys..Gonna go pick it up now.. Does anyone know how to do this??? im hoping this fixes my problem and i dont have to tear apart half my engine or take it somewhere. Is there a how too guide?? mine only leaks when you first crank it up too and my engine bay smells of antifreeze<a href=\"http://www.cardomain.com/id/marochk99\" target=\"_blank\">www.cardomain.com/id/marochk99</a>
i have a 150,000 miles on my car i knew something was bound to happen. i just hope its nothing serious. Crushedout, was the job a biatch to do?? could you explain wat you did??<a href=\"http://www.cardomain.com/id/marochk99\" target=\"_blank\">www.cardomain.com/id/marochk99</a>
picked up the plastic elbow peices today. Its was $3.57 no idea how to put them on but i guess its trail and error..lets hope that 3 bucks fixes my prob<a href=\"http://www.cardomain.com/id/marochk99\" target=\"_blank\">www.cardomain.com/id/marochk99</a>
It's pretty easy, Summer. Basically take off the water pump. Once you get the water pump off (try not to break the elbows, I broke off the tip of mine into the lower intake manifold) it's right there, attached to the pump housing. It's pretty simple and you just need a socket set IIRC.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Lol...ironically, my elbow seems to have broken again too. I'll be replacing mine tonight as well. :p1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
