Tech is great!!! Another question - FirebirdV6.com/CamaroV6.com Message Board
  • Tech is great!!! Another question
    The tech on this site is great. Has helped me fix all of my problems so far although i havent had a lot. Did some searching through tech and other forums and found out why my car was misfiring and running rough. It was the coil pack(#3 was shot).
    Finally took my firebird for a drive today after sitting for almost a year. Parked it due to the problem mentioned above which then i just decided to drive the camaro and park the bird. Car runs great and started up instantly but the brakes were a lil rusty and sticky which they always get from sitting.
    Since the car has been sitting nearly a year and not driven what do you guys recommend for the car? Any aftermarket fluids to flush through the engine/trans and any stuff like that? I did start the car and let it idle over that period it was parked. Btw oil looks clean and trans fluid is good.
    Also for my 93 camaro 3.4 a4....at around 45-55 the car gets a little shake in the steering wheel then goes away anytime between those speeds. Im thinking bad rotor? Has roughly 120k on it
    1994 firebird red t-tops 115K miles. needs paint job badly<br /><br />1993 camaro - gone<br /><br />1995 camaro - rdy to be drivin :)<br /><br />1987 camaro - slow *** v8 - blew it up ha
    Re: Tech is great!!! Another question
    probably a seperating tire or a slight imbalance
