I talked to zooomer at zzperformance he said if we get 7+ people that get about the same programming he will charge us 300.00 instead of 450.00. I know most of you guys are just like me and want to raise rev limiter remove governer, set shift points and so on. Lets get atleast 7 people in on this. Zooomer told me he has a thing that is way better than the maft+ and does the same things which is adjust timing and fuel. It is called the iccu in car control unit. He also told me that his mini afc will let you adjust your computer so you can run bigger ine=jectors, i just figured i would let you guys know about this.
ZOOOMER AT ZZPERFORMANCE WILL PROGRAM 96-97 COMPUTERS :)
This topic is closed.
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
<blockquote>quote:</font><hr>Originally posted by Nachius:
Yay I'm all about all of this I want all the stuff you mentioned above and a reprogram from 3.08s to 3.42s you think 1 little change like that would still fall under "about the same Programming"?
How do we get in contact with them?<hr></blockquote>
You might as well take off the speedlimiter and raise the rev limiter while you're at it - you might need it later :D2002 5-spd NBM Camaro
Details: www.1lev6.com
Maybe we should just send death threats to the people at hypertech and tell them to make a programmer for our cars... OR ELSE! That way I wouldnt have to drive all the way to Ohio (I'm assuming thats where zzperformance is?).<b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
why would you drive? all you have to do is send them your pcm. i doubt that would be out of the catergory, im sure its close enough [img]smile.gif[/img] ok well thats two for sure come on 5 more for the 300.00 price. any other guys willing to commit? i will just forward the names to him after we hit atleast 7 i hope this works out.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
Sounds like a god deal, but...How much hp increase are we talking for this reprogramming?
Don't get me wrong, I'm happy that we 95-97 3.8'ers finally found someone to spice up our computer, I just would like to get a pep-rally going in my head so I can squeeze the money up faster from the/our wedding bank account. (shhhhh!)
Marcsigpic
