taking off driver valve cover... - FirebirdV6.com/CamaroV6.com Message Board
  • taking off driver valve cover...
    what's the best way to take the coil packs off to get to the valve cover?
    and what else do i have to take off? I already got the engine lift brackets off
    Re: taking off driver valve cover...
    Okay, you can take it all out as one entire assembly:
    1) Remove the plug wires. Mark them so you know where they go
    2) Remote the 2 nuts on top of the coil-pack plate (13mm)
    3) Lift the whole assembly up so it comes off the studs, and then rotate so you can access the rear where the connection is.
    4) Use a 7mm socket (it might be 8mm, this is all by memory) to loosen the bolt holding the electrical connector in.
    5) ??????
    6) Profit!!!
    Hope that helps
    Representin' Team Red In The North
    Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
    Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
    Black/Red '02 Honda CBR 954RR Fireblade
      lol whats with the ???? and is profit a star trek reference? lol
        idk if the wires get in the way but mine would not lift off the studs with the wires on. it would hit the cowl. i wound up taking off the individual coil packs themselves
        1997 Camaro LS1 RS
        1994 Camaro - Sold
        1999 Trans am Vert - Sold
        A Few Mods....
          Weird. I've pulled mine off so many times that I could do it by feel before I relocated them.
          Hahaha, just drunken internet humor coming out of me.
            yeah i got it off with the coil pack on there.
            Its a good thing you told me there was a bolt in the back holding the wires in, At first i thought it was clipped in
              HOW THE HECK DID YOU GET THE ENGINE BRAKETS OFF!!!! i could not get the passenger side off at all. what technique did you try??? i would really like to know
                It involves wrenches and small arms. I found the best way was to break the bolts loose from under the car. I'll admit, it took me a whole lotta effort and a whole lot of penetrating lube, but I got em off eventually the first time.
                  I'm glad the penetrating lube was usefull
                    well, luckily for him hes talking the driver's side. there are two nuts holding the passenger side bracket to the back of the engine . you have to find a long open ended wrench, and go crazy on it. i actually got the wrench on there, put a pipe over the end for leverage, and used a bottle jack to push the wrench up till the nut came free. the nut closer to the engine is on much tighter than the one holding the transmission dipstick tube on.
                    Visit My F-Body Page
                      oh i had to take the pass side off as well haha.
                      I got under the car and was able to get the bolts off after a long struggle.
                      i took this picture afterwards
