do we have transmission coolers on 98 camaro v6?
transmission cooler?
Re: transmission cooler?
Not sure if there's any made specifically for us, but you can always get a generic cooler and install it yourself. From what I've been told, it isn't too bad if you've got some mechanical know how and the right tools.
is it the silver part in front of the black part of the radiator? and, does the same coolant in the radiator, cool the trans as well? or is there a separate reservoir to add coolant for your tranny?
you add trans fluid to the trans by adding it through the trans dipstick.
coolent is for your engine and has nothing to do with your trans.
Im pretty sure the trans cooler and the radiator are 2 different parts
and might i add that only autos have them
Originally posted by NkTyson06is it the silver part in front of the black part of the radiator? and, does the same coolant in the radiator, cool the trans as well? or is there a separate reservoir to add coolant for your tranny?
the tranny sooler is inside of the radiatior it used tranny fluid not coolant there are like 2 tubes or so in the radiatior set aside for the tranny2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
ok,,,,,,,,if u c your radiator on the passanger side you will notice two line pipes conected to your radiator tank,,,inside the radiator is the oil cooler it just circulates inside your radiator tank but in a separate you can say coppertank if im not wrong(help me here guys)....i dont have enough words to express my self in english,,,,remember im from aruba
yes there is a factory cooler, if you get a bigger stall or trans build you will want to install an aftermarket one which would mount to the front of the radiator.
