ok guys problem not solved... - FirebirdV6.com/CamaroV6.com Message Board
  • ok guys problem not solved...
    Got my car chekd and everything......abt the fuel pressure and running lean.......the only option they gave me was either to put bigger injectors or a new adjustable fuel pressure regulator...everything in my car is fine as per OEM requirements.
    Re: ok guys problem not solved...
    just get it tuned. that will be your best bet
    WAWA-A-HOLIC
      what year car is it? Have you changed O2 sensors? Fuel filter? has a recent mod created problems?
      Lean condition could be a number of things.. Anything else going wrong with the car?
        i'd hook it up to a tuner or something and take it on the road and watch what your o2 sensors are doing. mine had a bad ground (they all ground to the same place) and it was giving me an SES light and lean codes, even tho i was running really rich...
          i changed my fuel filter,3.4 v6 and i dont think so i have enough options as for the tunning....but yeah 02 sensors......dats something i need to try.....caz the shops over here dunno jack ****.....ooh it could be this it could be dat!!! dats all they gota say......n yeah SES light DOES NOT GO ON....even though plugs tell a diff story and the lack of power
            O2 sensors... those do alot as to what type of mixture your runnning
              get some new o2 sensors. Probably will fix the problem and if not, they will help improve your gas mileage again.
              bad o2s can cause lean conditions though
              http://www.bowtiev6.com/
                yeah ima gonna grab the bosch o2 sensors tommo!!!! i got the socket for it todat
                  good idea.. if i remember correct, they are only about $20-25 bucks each for our cars (3.4)... course, we use the old one wire, self heating sensors...
                  pretty easy to change, as long as the old ones aren't stuck in the pipe...
                    k changed them.......they were stuckkkkkkkkkkk........i had to take it to my friend shop and heatd them......n yeah the sensros were 39.99 each plus 14% tax.........Canada...i wish i lived in US...
                      did it fix it?
                        yeah.......its so much better now........im gonna drive it for sometime and than check the plugs again..
