Oil pressure drop - FirebirdV6.com/CamaroV6.com Message Board
Oil pressure drop
  • Oil pressure drop
    Hi,
    I have a prob with my 3.8 and i'm a little worried. My oil pressure when cold is about 55psi but when the car is warn the pressure is 40 but the pressure drop a very little when i accelerate (i can't see it move).
    What do you think? Bad sensor, oil filter, engine prob.
    When i bought the car in march the pressure was always at ~60.
    I have no noise comming and the car run great.
    Many thanks for your help.
    Re: Oil pressure drop
    start with checking your oil level
    WAWA-A-HOLIC
      oil level is good. In fact my oil pressure is pretty good for idle but not for in drive
        what does it do if you dont' have anything else on*ie a/c, heat. anything extra?*
        WAWA-A-HOLIC
          Same thing mine did. Your ok. I think GM says anything over 10psi is fine. This has been talked about in past. I wouldn't worry too much.
          Originally posted by kala
          TEAM BLACK!!!
          parting her out
            I will do an oil flush with 5w30 and delco filter. I will see.
            I want to buy an autometer guage to see the presure but does i can use the stock port for the pressure?
            if i don't use extra the pressure is the same. The baddest i have seen is the quart mark on heavy traffic this summer but with the time the pressure drop a little by little by day.
            Thanks
