First of all yes, I did a search, and I could not find exactly what I was looking for. I recently discovered that I have a bad injector an, and I was wondering a couple things... first off, are the Accel injectors any good? The price seems almost to good to be true at well under $300 for alll six. Any info will be appreciated. and secodly, I'm looking to uprade a little bit, and I've seen the calculators and have figured for stock, but I am planning for a little more. The 3.4 comes with 17 lb/hr injectors, and I was wondering what injectors I should put into the car. My mods are limited to the suspension and ur basic intake and exhaust, so I'm definitely not putting down much if any more power than stock. I'm trying to descide between 19's or 21's. If I go with the 21's, but do not have the power the warrant that size, will it damage my car at all?
Fuel Injection
Changing injectors will not do anything to help your cars performance. Your car is getting proper fuel right now. The only time you need to upgrade is when your injectors are being maxed out and can not put enough fuel in.
Since your not putting anything else in to power, dont even waste your time/money.
Stay with stock1999 Pontiac Trans Am M6 Far from stock.....
i put bigger injecters in my other camaro that i sold a long time ago... i noticed nonthing diffrent. Stick with stock.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
