Hi i'm about a thousand miles from chaning my oil should i put the sea foam in now? I'm not sure irf that is how your suppose to do it. Thanks
Sea foam..
This topic is closed.
[ April 20, 2004, 05:08 PM: Message edited by: navyblue2000 ]96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
Actually, use a full can in a full gas tank. And another full can in the EVAP line - you want the car to stall just as the can finishes being poured in. Then let it sit for 20 minutes or, then have fun trying to start the car for 5 minutes until it finally turns over. Expect it to have a high idle RPM at first, but it will calm down soon enough.
Oh yeah, and make sure your exhaust opens downwind from you, otherwise you're gonna choke on the smoke.-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
