Repost a million times Spark plugs - FirebirdV6.com/CamaroV6.com Message Board
  • Repost a million times Spark plugs
    How the hell do you get to passenger side ones? Driver side i got my hands in there but jezze talk about nothing on passenger any tips?
    Re: Repost a million times Spark plugs
    there is nexts to nothing on the bottom where am doing them from the control arm and trans mounts arent lettin me move
      It's tight, but you need to get them from underneath.
        use an open end wrench on the end of the spark plug socket(the end of a spark plug socket is like a nut), I know I had to do that on one or two.
          cut a small length of hose and use it to run them out and then back in.
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
