i got a code 1200 and when it was scanned it read that it was a manufacture code, i went to the dealership and they told me it was the injector control circut. i have never heard of this or even know where to start to fix or trouble shoot it. any help would be appreicated. thanks
non powertrain code
What does "non powertrain code" have to do with this? Powertrain means engine...fuel injectors are related to the engine, which is why the code is P1200. The P means powertrain. ;)
Could have a bad injector or connector or something.
Have you messed with the injectors at all lately? Any other codes?Matt
1998 Mystic Teal Camaro M5
when i got the code it said manufacture code. sorry for the misinterpertation. but the injectors are new ant the connectors will not lock onto the injectors. after the first i will be buying the new connectors from the dealership. do you think the is the problem. i never had that code before and they been like that for quite a long time.
New injectors with connectors that won't lock? Sounds like you've found the problem.Matt
