rpm surge - FirebirdV6.com/CamaroV6.com Message Board
rpm surge
  • rpm surge
    I have A 2000 v6 camaro and i noticed (mostly on the highway) that when the car is at a steady speed the rpm's begin to surge. it goes away whenever i accelerate of decellerate but then will eventually come back. im thinking its the coil packs since i have just replaced the spark plugs and wires but could anything else cause this?
    Re: rpm surge
    What exactly do you mean by "surge"?
    TEAM C6V6
      Re: rpm surge
      Mine was doing this and it was the coil pack
        Re: rpm surge
        clean your mass air flow sensor and change your fuel filter
        those are the typical causes of surges like that.
        if that doesnt take care of your problem i'd check fuel pressure and make sure its acceptible as long as its good run an aggressive fuel injection cleaner
          Re: rpm surge
          i mean the rpm gauge jumps up then falls down n jumps back up
            Re: rpm surge
            o yea and i already changed the fuel filter
              Re: rpm surge
              haven't taken out the MAF screen have ya?
              TEAM C6V6
