Hey i got a 2001 camaro 3.8L and i wanna V8 so can i got with an LS1 or LT1 which one should i go with also what else do i need to change for it
V6 to V8
Re: V6 to V8
sell the v6 and buy a 1998+ trans am, formula or z28.
Re: V6 to V8
Originally posted by Sean_99_3.8 View Postx2 for what you spend on the swap you could buy a 1998+ ls1 car.
Re: V6 to V8
no one is going to help you because theyll all tell you it costs to much, or its too hard, and to sell your car and get a new one
is it possible, yes.
is it cheaper than buying a new car? it can be.
your best bet is to find a wrecked donor car and have the whole thing with you. just swap everything over part by part. if you try to piece the swap together youll rack up the cost very quickly.
the only thing thats difficult, imo, is any interior wiring. but only because ive never done it i dont know whats involved. you do have to change the cluster over, but i dont know if the harnesses are all the same. either way its just wires.
the one thing i know is difficult is fueling. ls1s have a returnless system where the v6 is a return system. so you need to get fancy there. either use a v8 gas tank or use a corvette fuel rail which is a return style.<a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
Re: V6 to V8
Forget about the cost, what's money anyways, it comes, it goes, it's green, nuff said. Drop in a 500hp LS7 and a new trans from GM Performance Parts. You'll still need the donor car for parts and a new gauge cluster.
Re: V6 to V8
Originally posted by grayman View Postsell the v6 and buy a 1998+ trans am, formula or z28.
Unless you wanna put in some hybrid motor in the V6 body If you want an LS1 or LT1 just go buy one.
Evenutally I might toss in a Donovan or an LS2 in my car but thats of course if I decide to keep it.
