Error Code P1665 - FirebirdV6.com/CamaroV6.com Message Board
Error Code P1665
  • Error Code P1665
    Just got my car scanned at Auto Zone (SES light is on), got a Powertrain code 1665. Unfortunately, that code was not in their computer. The dude said it was probably 0665, and that it was a bad 02 sensor on the intake manifold. Anybody know if he is right, or if there is a 1665?
    - John<br />Black 98 Firebird M5<br />Favorite Oxymoron: Honda Power
    P1665 = EVAP Vent Solenoid Control Circuit, and it will illuminate MIL (SES).
    [source - Chilton Tech Manual]
    --Traded In--<br />1998 Navy Blue Metallic Camaro (RS)<br />3.8L V6 w/4L60E Auto<br />Sport Appearance Package<br />T-Tops - Loaded<br />_ _ _ _ __________________ _ _ _ _ <br /><br />--New--<br />2003 Victory Red S10 Xtreme w/Silver Stripes<br />2.2 L4 w/MW2 5 Speed Manual<br />LS Package
      cool. thanks for looking that up.
      Anyone know how to fix it?
        Replace the O2 Sensor and it should clear up.
        <b>« Red <i><a href=\"http://sandman.v8tec.com\" target=\"_blank\">Firebird</a></i> »</b>
          Evap. Vent, isn't that associated with the evaporative control for the gas tank? Used to be a charcoal canister on older cars, with a vacuum line to draw the evaporated fumes from the canister to the intake when the car was started?
          Is this the code you get when the gas cap isn't screwed on tight....?
            The Auto Zone guy was telling me that I needed to check the 02 sensors on the intake manifold. I wasnt aware that there were any 02 sensors on the intake side - I thought they were all related to exhaust gasses, before and after the cat. Did the Auto Zone know what he was talking about? If he did, where are the sensors on the intake manifold?
              Let's see, on the intake side, there is IAT, then maf, then tps. That's all I can think of. Oh, and EGR. Definitely no O2. Sounds like the guy was not quite on the right wavelength...
                Thats what I was thinking...what does the EVAP solenoid have to do with an 02 sensor? And yes, the EVAP vent has to do with Charcoal canisters and all that stuff, I guess they arent just on older cars.
                So what do I need to do to get this code to go away?
                  OK first off AutoZones response to any problem from the PCM is tro replace the O2 sensor, they have an imcomplete list of error codes too. Don't trust them,
                  The code you got was for your Evap canister like r&ksport said. Dont mess with the 02's they are expensive and not the reason for your error code.
                  There are no 02 sensors in the intake manifold, which is more proof that they are idiots. There are 4 O2's, right manifold, left manifold, pre cat and post cat..
                  But back to your actual problem. Try taking the gas cap off and putting it back on. Sometimes sudden changes in pressure inside the gas tank or a loose gas cap can give EVAP errors. If the light does not go away after a few more driving cycles, have it checked out by a mechanic.
                  If you have any more questions just drop me an email, and I'll see if I can help you.
                  Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
                    tightening gas cap will not repair this problem. perform circuit diagnosis on evap canister purge solenoid and related circuits. check for proper voltage from pcm at the correct time. this may require tech2 scan tool for interactive testing of evap canister purge solenoid.
                    AZ scans codes so they can sell you parts. period. it is a marketing technique.
                    ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
                      Here is more info than you should need. including diagnostic information.
                      P1665.pdf
                      I hope this helps.
                      [ April 19, 2002: Message edited by: P-nut- ]</p>
                        Thanks guys, that should help a lot. Hey P-Nut, where do you live? I am back home in Germantown right now.
                          Up by outback steakhouse at the corner of great seneca and wisteria.
