Is there any company out there that sells a kit for relocating a battery to the rear?
Battery Relocation.........
Black 99 M5 Camaro \"6BANGER\"<p>Sport Appearance Package, Whisper Lid, SLP Cold Air Kit, K&N Filter,Dynomax Custom Cat-Back, BMR STB, Jet Stage II Module, Centerforce Dual Friction Clutch, Hurst Shifter with Custom Short Stick, RKSport 2\" Drop Springs, SS Hood, Poly Tranny Mount & TA Bushing, SLP 3.42 Gears with LSD, All Amsoil Synthetic LubricantsTags: None
<blockquote>quote:</font><hr>Originally posted by xjarayax:
Summit Racing-
http://store.summitracing.com/partdetail.asp?part=680
$42.95
That's what I used.
Sam<hr></blockquote>
I thought it didnt fit?2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
the box didnt fit exactly where i wanted it to, but it's still a decent price just for all the wires and stuff. heavy gauge wire that's like 20 feet long is not cheap.
SamAIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
I thought they did that for more room in the front, more weight in the back? Not sure for what tho, custom SC or nitros? Not sure at all... but sure would be nice to not have to run the wires for amps and such through the firewall!RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
To relocate weight... getting it off the nose and putting it over the rear axle. Nose definately lifts up a lot higher and much better traction to be had. It's a lot of work and there are a lot of little issues you have to work out.
I could never get the starter to crank right, it would always cick over 3-4 times before starting the car, so I moved the battery back to stock location, using the stock wires, bur left the relocation wires in place going to the rear so I can relocate to the back just for strip use.
I didn't want to have to buy a new starter and couldn' find my specific problem so that was my last resort.
You say that the case didn't fit perfectly, right? If you have a Optima Red Top battery, do you need the case? Are they not sealed? Thanks for any input!1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
<blockquote>quote:</font><hr>Originally posted by BattyV6:
You say that the case didn't fit perfectly, right? If you have a Optima Red Top battery, do you need the case? Are they not sealed? Thanks for any input!<hr></blockquote>
NHRA Regulations say: (most tracks do enforece this)
The battery still has to be sealed inside a box; regardless if the battery is a wet or dry cell. If its a wet cell battery then you have to go a step farther and VENT the box outside the car.
They require the battery to be in a box for saftey reasons, in the unlikely event that the battery exploded do you want acid on your skin? Start a fire? etc.... You also have to have a kill switch located on the back of you car so that if a wreck does occur they can turn the car off / disconnect the battery from outside the car.2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
Yeah, but I won't be participating in any NHRA sponsored events anytime, or even, in the near future. All the local strips around here don't even check the car, at least for time trials.
