Hey i talked to a guy a the gm dealership and he said he would be able to scan my car to see if there is anything advancing the timing causeing my rattle under load,just wondering if its worth $45 cad and will he be able to see very much on a 97 firebird,like check the timing and knock sensors and injectors??
GM's $45 scan??
Re: GM's $45 scan??
Depending on the scanner he uses, OBD II gives alot of info. I'm not sure if they go into the injector detail, but defineatley the timing, any pending codes, O2 readouts, throttle position, lots of info. I'm not sure what Autozone has, but I know they will scan your car for free if your having problems. The dealership should have better scanners than AZ tho. The better ones will allow it to gather the data while driving the vehicle. Lots of good info if you know how to decipher it all.
Re: GM's $45 scan??
Originally posted by poncho1961 View PostDepending on the scanner he uses, OBD II gives alot of info. I'm not sure if they go into the injector detail, but defineatley the timing, any pending codes, O2 readouts, throttle position, lots of info. I'm not sure what Autozone has, but I know they will scan your car for free if your having problems. The dealership should have better scanners than AZ tho. The better ones will allow it to gather the data while driving the vehicle. Lots of good info if you know how to decipher it all.
Re: GM's $45 scan??
I thought obd2 just told if codes were being thrown? i need to know if something is advancing the timing that isnt causeing a code to be thrown? im gonna see if they can see anything i guess ,cause i had enough of this rattleing /pinging and no one seems to know what is causeing it.thanks for the help!!
Re: GM's $45 scan??
$45...we charge $82, but that is an hours labor to tell you what is worng not just what the code is. GM dealers use a scanner called a tech 2. it can do all sorts of stuff. It can read codes in all areas of the car such as bcm and pcm and tcm it can also command everything off and on it also shows map sensor readings maf readings and injector stuff. it is a pretty hi tech peice of equipment that no dealer can live with out. i can do all this stuff on my 96 so i know you can do it on your 97.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Re: GM's $45 scan??
The OBDII scanners can tell you which cyl. are misfireing the most and alot of other stuff, so if you have the $45 it couldn't hurt to have them check it out. Have you fixed your exhaust leaks? I would fix what you know is bad first then have it scanned if it is still having problems.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: GM's $45 scan??
Im not fully sure i have an exhaust leak, thats what i thought this rattle was but my mechanic checked it out and could not see any soot around the manifolds and said everything looked tight,so he and i are thinking pinging,what do u think??
Re: GM's $45 scan??
I haven't seen your car , so I can't tell you anything, you can't just look at it and say there is no exhaust leak. When cool start the car and moved your hands around the egr, exhaust manifolds to feel for leaks. Might have to do it a couple of times since the car will heat up fast and there is no reason to get yourself burned when you can shut the car off and let it cool down and start again.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: GM's $45 scan??
Originally posted by LEOMAC23 View PostHey i talked to a guy a the gm dealership and he said he would be able to scan my car to see if there is anything advancing the timing causeing my rattle under load,just wondering if its worth $45 cad and will he be able to see very much on a 97 firebird,like check the timing and knock sensors and injectors??Team NoVa
Re: GM's $45 scan??
Originally posted by david8399 View Post$45...we charge $82, but that is an hours labor to tell you what is worng not just what the code is. GM dealers use a scanner called a tech 2. it can do all sorts of stuff. It can read codes in all areas of the car such as bcm and pcm and tcm it can also command everything off and on it also shows map sensor readings maf readings and injector stuff. it is a pretty hi tech peice of equipment that no dealer can live with out. i can do all this stuff on my 96 so i know you can do it on your 97.
