fuel pressure sending unit - FirebirdV6.com/CamaroV6.com Message Board
  • fuel pressure sending unit
    Okay I am ready to install my electric fuel pressure gauge and thats easy but what I am trying to figure out where do the sending unit goes it has a thread on the end of it but nothing inside my engine bay fits the sending unit can someone help me out to find this part inside my engine pictures would be nice cause I am lost completely
    Re: fuel pressure sending unit
    You will need a adapter that goes onto the fuel rail and then the sending unit screws into the adapter. I'll see if I can get a pic. Search the nitrous section for the part# for the adapter. You'll need a tire removal tool to unsrew the pin inside the port so fuel will come out once you get all the parts to hook up the fuel pressure gauge. My Autometer Fuel gauge has been great going on 7 years with no problems,knock on wood.
      okay I just bought this will this work http://store.summitracing.com/partde...rt=SUM%2DG1710
        that will work if you want to splice your fuel line. Let me warn you that clamping the stock lines is a pain in the butt to get to seal.
        A better route would be to get the brass fittings that fit the schrader valve on the fuel rail
        http://www.bowtiev6.com/
          yeah but its already paid for now there is a little screw by the fuel lines on the drivers side is this where the adapter must go
            you will have to cut and splice it into the line off your fuel rail. There is no screws for this. it is a nylon hose.
              Its better to go off the fuel rail as stated.
                hey can you give me an exact picture of which fuel line to cut so I will know or is it just any fuel line I choose to cut
                  you have to cut the one going to your fuel rail
