I think i need a new relay on my 98 firebird.. every time i turn my ignition on they automatically come up. My manual shows NO relay.. Where is this located or what else could this problem be????
headlight relay
Light sensor? No I don't think firebirds have them. I had strange headlight issues, it turned out that the wiring harnesses were badly corroded. Check them out (behind the headlights, remove the plastic trim ring first). If you pull them apart and see junk inside that could be your problem. I cut mine out and spliced the wires together, everything was all better after that. That has been a year ago now, still just fine.<a href=\"http://photos.yahoo.com/bethann375\" target=\"_blank\">http://photos.yahoo.com/bethann375</a> <br /><br />1999 firebird, dark blue metallic, 5-speed, t-tops, kenny brown sfc\'s, high-flow cat, dynomax super turbo muffler, K&N filter, silver Firebat decals
