GHETTO MODS - FirebirdV6.com/CamaroV6.com Message Board
GHETTO MODS
This topic is closed.
  • GHETTO MODS
    here is some easy N.R.S. graduate mods that work and i have done.
    total cost: $9.76$
    total work time: 35 minutes
    use eye protection
    used a pair of pliers and broke off stock fins under air lid, makes clean break, sawed off center fin on lid. reinstall.
    20 ft. 8 awg wire (thhn only), 1 square D ground clip, (both available at home depot, 5$ for wore, 3.47 for ground terminal)
    grounded throttle body, struts, chassis, EGR. ran nicely this looks great and is effective, reduced noise level in radio, mild redux in engine, faster, stronger start
    92 25th rally sport garage baby, 97 30th rally sport, 01 camaro garage baby. obsessive compulsive camaro fan. id rather push a camaro then drive a rice burner.
    works even better if u take a dremel to it afterwards and smooth it all out, AKA the homemade whisper lid
    Stephen Cruikshank<br /><br />Selling some stuff so all I have left is the FRA, !MAF Screen, whisper lid, Holley PowerShot, 3\" catback, and 160* thermo on the car<br /><br />I Practice Street S.M.A.R.T.S. - do you?
      nice , ill try that too, thanks
        Did you get rid of the air baffles behind the air lid and use the home depot mod for the intake into the throttle body?
        New Toy Red 94 Formula LT1
        RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
        crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
        The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
          no to the baffles, im thinking of using some pvc, i just did the grounding stuff with home depot, im trying now to engineer a way to seal the baffle and just keep it, since paying for 2 of 3 cars and 2 kids gets expensive , i will try most anything to supe it up a bit, i raised my intake 1/2 inch with washers and it make a minimal difference , but there is more air now, as long as it looks good and not crappy
            jsut get a 3 in to 3 in. pvc coupling $0.98 at home depot and grind the ridge out in the middle works great.
              i just came from there and actually bought it but it is not long enough.
                Mine fit fine... actually thought mine was slightly too long.
                  look into cig ;) 3 inch pvc doesn't add any HP.. no difference.. exhaust note might be different, but all-in-all it's all the same. Sometimes you can hear engine wooosh under the hood.
                    i just did it and i think it made a difference, seemed to have better pick up, but the IAT was disconnected , i dont know if that would make a difference , thanks much mustangeater.
                      honestly I thought mine was worthwhile... not leaps and bounds but better then shaving my lid and putting a k&N in.
                        any other easy, at home mods??
                          theres a bunch of track mods but it wouldnt be good for regular driving
                          1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
                            free ram air...160* thermo (not free, but cheap).
                            getting rid of the plastic piece in the middle of the airbox outlet isn't a good idea, i think. it's there to smooth out the air flowing in, isn't it?
                            \'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
                              The air silencer help air flow better?
                              Only reason its on there is to reduce engine noise. It restricts airflow.
                              If you don';t trust ghetto mods you can alwasy buy this.
                              http://www.slponline.com/view_produc...RTNUMBER=23065
                              But then again a piece of pvc will do the same thing.
