12v or 14.4 - FirebirdV6.com/CamaroV6.com Message Board
12v or 14.4
  • 12v or 14.4
    " Most car batteries, though rated at 12 volts, actually deliver 14.4 volts. "
    I read that on crutchfield. Is that true?
    <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
    Yes. But it depends on what load/current is being drawn from them. I think the 14.4 is when your alternator is working. I think if you just measure of battery sitting there, it should be closer to 12.6v.
    DEE
    1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
      The battery in your car is a 12.6V battery.
      The charging system in your car is a 14V system.
      Basically the alternator is charging the battery above 12.6V....generally around 13.8-15.2V is normal with the engine running. Any higher or lower and you have a problem.
      Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
        When I was selling batteries, they put out about 2.2 volts per cell. That comes out to about 13.3 volts for a 12v battery. The voltage can vary depending on how well the battery is maintained, but I have never seen one higher than 13.3 volts.
        <a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
