How do I remove Window Crank? - FirebirdV6.com/CamaroV6.com Message Board
  • How do I remove Window Crank?
    I need to get my door panels off and I have everything figured out except the window crank. How do I remove this? My guess would be there are two clips but I can't see them. Any help would be much appreciated!
    Thanks
    2000 Z28 M-6<br />Loudmouth, TSP Lid, MAF Ends<br />330 rwhp
    They're held on by clips that are shaped like 3/4's of circle. You could push it off using two flat-head screwdrivers on each end of the clip.
    The easiest way would be to buy a tool from an auto parts store that's designed for pulling off those clips. It's been awhile, but I paid less the $10 for it, and it's a usefull tool to have around.
    edit: to add that the clips are right behind the cranks and in front of the plastic rings that fit into the door panel.
    [ February 01, 2003: Message edited by: navigatorbob ]</p>
    <a href=\"http://www.cardomain.com/id/edogg_127\" target=\"_blank\">1999 red 38000 Camaro</a><br />Leaking rear main seal (not really a mod though)
      push the panel in a bit right behind the crank, youll see a silver metal ring (its like 3/4 of a ring, like Navigatorbob said) move the crank until you see the top of the ring, where the ends are (i think you have to do this). Then use something like a screwdriver and pop that thing off. watch out and see where it flies off to. Replace same way.
      Cp
